Regular Contributor I
AppleTV devices
I have a customer who has a device acting as an AppleTV server which sometimes becomes unreachable by other devices. I checked and this device was in the users list rather than the servers list. We connected a laptop as a test and changed it from a user to a server, but again the device was still seen as a user rather than a server. I don't know much about Airplay and would apprectiate if anyone could help.
Controller is a 3600 running 6.4.2.4 with the default Airgroup settings.
Re: AppleTV devices
Is it on the wired or wireless network?
Tim
Tim Cappalli | Aruba Security
Re: AppleTV devices
Both are on the wireless.
Re: AppleTV devices
Do you have active wireless discovery enabled?
Tim
Re: AppleTV devices
I have checked and this setting is disabled, should I enable it?
Re: AppleTV devices
It may help. It probes from the controller down to the client to discover services.
Also, Apple recommends AirPlay servers be on the wired network.
Tim
Re: AppleTV devices
I've enabled it but it still seems to be in the same state. It seems odd that in this wireless connected world these devices would have to be wired, I'm not sure how the customer is going to take this its a school and I think they expected the device to be available wirelessly.
Re: AppleTV devices
Can you turn up a user debug on the client? You should see discovery messages in the logs.
Re: AppleTV devices
I have limited access for debugging, but I've noticed that bug ID 116556 describes what they are seeing perhaps this might be fixed in the latest version of code?
Re: AppleTV devices
If you're able to, yes. There are a few fixes in 6.4.2.8 and 6.4.3.2.
Tim
