Occasional Contributor I
Apply SSID policy to AP 105,205 and 3x5
I don't know since when but now when I want to create a new SSID and to apply it to all my APs I didn't have the same behavior following sites.
I am using a cluster of 3400 with the latest version available and I am using 3 kind of sites
site 1 with AP105 only
site 2 with AP 205 and 325
site 3 with AP 105,205 and 325
with old and even new SSID when I want to apply it
Site 1 : SSID is well applied
Site 2 : SSID is well applied
site 3 : only AP 205 and 305 recieved the policy but not 105
And I don't know if I missed something or how I can troubleshoot why on site with AP 105 and 205 , AP105 didn"t receive the SSID ?
thanks for your help
Regards
Re: Apply SSID policy to AP 105,205 and 3x5
How is that SSID configured different from the other 2?
no I am sure of my parameter
Site with 2 different model AP105 and AP205: AP105 didn't receive the SSID
site with AP105 only works
how can i troubleshoot such issue ?
You need to start by comparing the differences between configurations on each SSID.
You can also type "show ap bss-table" to see what SSIDs are really being broadcast from each access point.
Typing "show profile-errors" might also give you an idea what your problem is.
In fact I found the solution and it's about the number of SSID supported by the AP105 (16 BSSID) so in my case 8 BSSId per radio( 2.4, 5G) and I reach this limit.
Sorry and many thanks to people who helped me.
