After some research, I probably know the answer to this but hopefully somebody can help and advise.
I've inherited an Aruba 800 controller (yes, its a few years old!) which was working but needed some attention. It was decided by somebody higher up the chain (!) to reset the controller and start again from scratch - we have 10 remote AP's over 5 sites.
Anyway, someone performed a 'write erase all' and factory defaulted the unit. After re-entering all the required settings, we're able to provision AP's again but get the notification 'error - role authenticated is unknown' .
After some googling, it looks to me like some licences were deleted after the factory reset. The problem is i've inherited this and have no idea when it was purchased or any licence keys that came with it.
Is the error critical? Can I continue to use the controller safely in its current state? Is it possible to remove the notification?
In terms of what I want to achieve, the end result should be that I advertise one SSID with WPA2 PSK across all 5 sites and a Guest SSID using the captive portal. Do I need any licencing to do this?
Thanks in advance for any help.
