Aruba AOS upgrade to 6.3.1.3 on 3400 controller turn APs in air monitor mode issue.
  • 1.  Aruba AOS upgrade to 6.3.1.3 on 3400 controller turn APs in air monitor mode issue.
    Posted May 31, 2014 10:49 AM
    Hello ,
    I am having problem in upgrading aruba controller 3400 AOS ,As i upgraded to new verison 6.3.1.3 my APs turned into air moniter mode,can some body adivce me how to fix this issue.
    #3400
  • 2.  RE: Aruba AOS upgrade to 6.3.1.3 on 3400 controller turn APs in air monitor mode issue.
    Posted May 31, 2014 11:08 AM
    What model of AP? What AOS did you upgrade from?
  • 3.  RE: Aruba AOS upgrade to 6.3.1.3 on 3400 controller turn APs in air monitor mode issue.
    Posted May 31, 2014 11:10 AM
    also, what is your regulatory domain?
  • 4.  RE: Aruba AOS upgrade to 6.3.1.3 on 3400 controller turn APs in air monitor mode issue.
    Posted May 31, 2014 11:26 AM
    Mobility controller 3400
    i upgraded from AOS :6.1.4.1 to AOS 6.3.1.3
  • 5.  RE: Aruba AOS upgrade to 6.3.1.3 on 3400 controller turn APs in air monitor mode issue.
    Posted May 31, 2014 12:16 PM
    Regulatory domain is US.
  • 6.  RE: Aruba AOS upgrade to 6.3.1.3 on 3400 controller turn APs in air monitor mode issue.
    Posted May 31, 2014 05:34 PM
    What's the model of the access points?
  • 7.  RE: Aruba AOS upgrade to 6.3.1.3 on 3400 controller turn APs in air monitor mode issue.
    Posted Jun 01, 2014 04:35 AM
    We are using two AP models AP93 and AP105,both of them turned into air moniter mode.
  • 8.  RE: Aruba AOS upgrade to 6.3.1.3 on 3400 controller turn APs in air monitor mode issue.
    Posted Jun 01, 2014 04:59 AM
    Dear Haris bro,
    Please confirm , what country code is set on controller ? is country code is GB or US ?
    If its GB then you cannot set the regulatory domain of AP profile to US. Country code and regulatory domain profile for AP's must be same.
    On Monitoring tab, All Access points -> some AP's which are not working properly having E-Flags means regulatory domain miss match..
    Same issue with me at IMH
  • 9.  RE: Aruba AOS upgrade to 6.3.1.3 on 3400 controller turn APs in air monitor mode issue.
    Posted Jun 02, 2014 01:12 AM
    (The above post - seems to be your solution)
    BUT :)
    If everything is US (controller / AP'S / reg-profile) , then try to uprgade to newer AOS (6.3.1.7) and see if problem solved.
  • 10.  RE: Aruba AOS upgrade to 6.3.1.3 on 3400 controller turn APs in air monitor mode issue.
    Posted Jun 02, 2014 02:33 AM
    Dear Experts,
    thanks for the help,i resolved my issue by chaning regulatory domain from US to GB and it solved the problem.Thanks..
