Aruba AP-105 restart few times after upgrade to AOS 8.2
  • 1.  Aruba AP-105 restart few times after upgrade to AOS 8.2
    Posted Nov 15, 2017 02:43 AM
    Does AP 105 compatible with AOS 8.2? Cause I try migrate the AP 105 from Aruba 3200 (AOS 6.4.3.7) to Aurba 7010 (8.2.0.1) AP 105 it was keep on restart and on the Aruba 7010 web console indicate say "Upgrading".
    Please advise.
  • 2.  RE: Aruba AP-105 restart few times after upgrade to AOS 8.2
    Posted Nov 15, 2017 02:46 AM
    Is it possible that the AP can "discover" two controllers with different firmware on the same network?  If yes, please remove one controller.  The AP-105 should work on AOS 8.2.
  • 3.  RE: Aruba AP-105 restart few times after upgrade to AOS 8.2
    Posted Nov 15, 2017 03:03 AM
    AP105 only able to discover one controller only which is Aruba 7010.
    When I try to provision on new Aruba 7010 controller it always pop up error message as attached.
