Aruba Controller 650 Uplaod Firmware from CPBOOT
This thread has been viewed 27 times
  • 1.  Aruba Controller 650 Uplaod Firmware from CPBOOT
    Posted Apr 12, 2016 10:59 AM
    Hi Folks,
    i need to upload the 650 controlleur from the flash ? some one can help ?
    Regards
  • 2.  RE: Aruba Controller 650 Uplaod Firmware from CPBOOT
  • 3.  RE: Aruba Controller 650 Uplaod Firmware from CPBOOT
    Posted Apr 12, 2016 11:31 AM
    Thanks Joseph ,
    but i need to fromat and then to upload the firmware , i found in the database a good tutorial :
    http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-I-upload-an-image-from-CPBoot-using-setenv-ethact-xlr/ta-p/177958
    but i cant ping my pr from the conrolleur, and  i can't upload the firmware from my tftp server (my Laptop).
  • 4.  RE: Aruba Controller 650 Uplaod Firmware from CPBOOT
    Posted Apr 12, 2016 11:43 AM
    That tutuorial only applies to 3000 series controllers, so no, it is not a good one..
    Did you see the LAST post in the thread I posted above?  http://community.arubanetworks.com/t5/Wireless-Access/650-ArubaOS-upgrade-from-USB/m-p/94940/highlight/true#M16277
    setenv ethact xls_gmac1
    setenv ethprime xls_gmac1
  • 5.  RE: Aruba Controller 650 Uplaod Firmware from CPBOOT
    Posted Apr 12, 2016 12:08 PM
    that's what i got
    _____
    cpboot> setenv ipaddr 10.0.0.1
    cpboot> setenv netmask 255.255.255.0
    cpboot> setenv gatewayip 10.0.0.2
    cpboot> setenv serverip 10.0.0.2
    cpboot> setenv ethact xls_gmac1
    cpboot> setenv ethprime xls_gmac1
    cpboot>
    cpboot> ping 10.0.0.2
    Using xls_gmac1 device
    ping failed; host 10.0.0.2 is not alive
    ______
    it haven't work any other idea.
  • 6.  RE: Aruba Controller 650 Uplaod Firmware from CPBOOT
    Posted Apr 12, 2016 12:40 PM
    Do you have it plugged into the second port from the left?
  • 7.  RE: Aruba Controller 650 Uplaod Firmware from CPBOOT
    Posted Apr 12, 2016 12:47 PM
    The 650 I think requires you to be in a specific port. This is what I have from my notes a long while back (RUN AT YOUR OWN RISK):
    The 6xx models use a JFFS2 F/S on raw NAND Flash. To delete and recreate the /flash partition from cpboot you need to run the command actually a u-boot alias in the environment) "run wipe-out-flash". If cpboot can't find the command alias for "wipe-out-flash" you need to execute "purgeenv" first. This function is implemented in the default environment. The image partitions get deleted and recreated whenever "upgrade" is used to upgrade an image partition.
    1. Console into the controller's serial port and reload the controller and interrupt the boot to 'cpboot>'
    2. From 'cpboot', enter 'purgeenv'
    3. From 'cpboot', enter 'run wipe-out-flash', this will wipe the flash
    4. Connect your laptop ethernet interface to Gig1/1
    5. Start up the TFTP server and put the firmware you wish to load into the TFTP directory
    6. Run the following commands to set the IP address and TFTP server IP
    a. setenv ipaddr <ipaddress>
    b. setenv netmask <netmask>
    c. setenv gatewayip <gateway>
    d. setenv serverip <tftp-serverip>
    7. Enter the command 'upgrade 0 <firmware-name>'.
    8. Once done, enter 'boot' at 'cpboot>' to reload the controller wiht the new firmware.
    Once this is done, the controller will be back in factory-default mode and can be re-configured, restored, etc.
  • 8.  RE: Aruba Controller 650 Uplaod Firmware from CPBOOT
    Posted Apr 30, 2018 05:54 PM
    I have followed your steps with no success. After wiping and connecting my laptop, there is no basic IP connectivity.
    Please help.
    Mike
  • 9.  RE: Aruba Controller 650 Uplaod Firmware from CPBOOT
    Posted Apr 30, 2018 07:19 PM
    "The 650 I think requires you to be in a specific port.".  Try either the leftmost or the rightmost port to see if you have connectivity.
  • 10.  RE: Aruba Controller 650 Uplaod Firmware from CPBOOT
    Posted May 02, 2018 01:53 PM
    Hello -
    Follow up: I got it to work, I had to hard set my laptop's NIC to 10MB-FULL in order to get connectivity.
    Thanks -
    Mike
  • 11.  RE: Aruba Controller 650 Uplaod Firmware from CPBOOT
    Posted Nov 28, 2018 07:29 PM
    That is correct, I did mine that way as well. DOnt know why we have to har code the NIC to 10/Full DUPLEX but it worked. I was able to upload my firmware.
