Aruba Controller: MAC Auth and Captive Portal (together)
  • 1.  Aruba Controller: MAC Auth and Captive Portal (together)
    Posted May 06, 2015 09:22 AM
    just a quick question as I don't have the oportunity to test this right now.
    Is it possible to have a SSID with MAC Auth as first and CaptivePortal as a second authentification (some kind of 2-factor auth)?
    A customer wants to protect a SSID with Captive Portal and MAC Auth because only a few devices should be able to join the SSID.
    Only known MAC adresses should see the Captive Portal. Unknown MAC adresses shall be blocked.
    Clearpass is no option.
  • 2.  RE: Aruba Controller: MAC Auth and Captive Portal (together)
    Posted May 06, 2015 09:24 AM
    Yes. Use the internal database to store your MAC address and set their role
    to be the captive portal registration role.
