Aruba Controller Physical Connection and Network Latency/ Saturation
  • 1.  Aruba Controller Physical Connection and Network Latency/ Saturation
    Posted Jul 31, 2012 10:37 AM
    We have a 6000 controller with an M3 card. As of now, 1 gigabit port is connected to our wired network through a trunk port. The controller is a master and there are about 30 APs currently terminated to it. We are planning to place 100+ more APs. We are planning to use the 10Gb port in the future but I am wondering what commands or paramters should we be looking at to see if the 1 Gb port we have is currently functioning properly without saturation or dropping packets? Thanks.
  • 2.  RE: Aruba Controller Physical Connection and Network Latency/ Saturation
    Posted Jul 31, 2012 11:03 AM
    show interface gigabitethernet <slot/port>
    show port link-event
  • 3.  RE: Aruba Controller Physical Connection and Network Latency/ Saturation
    Posted Aug 17, 2012 01:18 AM
    We will have about 150 APs in a campus deployment with a master controller. We are wondering how many 10GB or 1GB ports should be use as members of a port channel to trunk to our switch to avoid any congestion. How do you guys usually connect the controller to your switch/ router. Do you usually use a port channel and add all ports to this port channel? Or do you only use a few ports added to the port channel?
  • 4.  RE: Aruba Controller Physical Connection and Network Latency/ Saturation
    Posted Aug 17, 2012 01:44 AM
    I typically (as in 95% of the time)  run with two 1Gbps interfaces in aggregation mode.
    That provides, under normal conditions, up to 2 Gbps of throughput... and also resiliancy against any one port/SFP/Cable issue.
    Haven't seen this 'bottle neck' a deployment yet... e.g. haven't found the need to light up other ports in aggregation mode in the vast majority of deployments.
