Aruba Instant 304 and External Antennas
  • 1.  Aruba Instant 304 and External Antennas
    Posted Jun 25, 2018 10:53 AM
    I have the external antenna AP-ANT-38 with 3 antenna wires labeled -45, 90 or V, and +45. On the AP-304, the ports are labeled ANT0, ANT1, and ANT2. I couldn't find documentation that state which should be matched up, anyone have this information?
  • 2.  RE: Aruba Instant 304 and External Antennas
    Posted Jun 25, 2018 01:20 PM
    It does not matter. As long as you connect all three.
  • 3.  RE: Aruba Instant 304 and External Antennas
    Posted Jun 26, 2018 09:23 PM
    ap-ant-34 is a connector type  - RP-SMA ap 304 model antena The connector type is the same.  - AP-304 / IAP-304: Three RP-SMA connectors for external
  • 4.  RE: Aruba Instant 304 and External Antennas
    Posted Jun 27, 2018 11:17 AM
    Yes, same is true for AP-ANT-38
