last person joined: 4 hours ago
Aruba Instant and Upnp/SSDP multicast problem with Airtame Device
  • 1.  Aruba Instant and Upnp/SSDP multicast problem with Airtame Device
    Posted Apr 16, 2018 03:24 AM
    I use "Airtame" products to deliver content to my meeting rooms, this product uses SSDP/Upnp discovery to display devices available on the network. The concern is that this discovery does not work when my Airtame product is connected to the WIFI terminal. I have no problems on my wired network.
    Airtames products are also Airplay compatible, on this point I have no worries, the discovery works well.
    For information:
    I have a classic network without any Vlan or ACL.
    I added this service in Airgroup : urn:airtame-com:device:airtame:1
    Thanks for your help
  • 2.  RE: Aruba Instant and Upnp/SSDP multicast problem with Airtame Device
    Posted Apr 16, 2018 05:46 AM
    For information I found the following 2 debug commands on this same forum :
    show airgroup blocked-service-id
    show airgroup blocked-queries
    So I added: _airtame._tcp in SERVICE ID
    It is no longer blocked after verification with the famous command.
    On the other hand obviously I have a "Queries" of blocked
  • 3.  RE: Aruba Instant and Upnp/SSDP multicast problem with Airtame Device
    Posted Apr 19, 2018 02:30 AM
    the solution has been found
    When you only have one vlan, you should not activate the Airgroup services.
    Everything's okay now.
