Dear all,
I have an issue with my VIA connection, the users can’t access to the LAN, only to the controller.
The configuration is the following :
- Two VLANs are used on the controller, 1 (default) and 6.
- IP adresses of the VLAN 6 are assigned to the VIA users (in the VPN service part)
Once they are authenticated, it seems that the users exit from the controller using the VLAN 1 even if their IP adresse is in VLAN 6.
We tried to give them an IP adress in VLAN 1 and it works well.
Is there a way to force them to access to vlan 6 ?
Thanks in advance for your help !
