Occasional Contributor I
ArubaOS 8.x AAC same as HA fast failover?
If I use bridge mode SSID in ArubaOS 6.x then HA Fast Failover redundancy is not available.
In ArubaOS 8.x there is new feature which is AAC. This feature is working same as HA Fast Failover in 6.x so the bridge mode SSID is not working or it is available in AAC.
Thank you.
Re: ArubaOS 8.x AAC same as HA fast failover?
Clustering (an AOS 8 feature) does not support bridge mode SSIDs. Also, Clustering is a far more advanced feature than HA/APFF.
Jerrod Howard
Thank you
