ArubaOS 8.x VMC Trunk not working on ESXi
  • 1.  ArubaOS 8.x VMC Trunk not working on ESXi
    Posted Oct 17, 2017 09:45 AM
    Hi all
    I try to setup the VMC with one trunk port.
    My Port configuration from VMC:
    interface gigabitethernet 0/0/0
        description "GE0/0/0"
        trusted
        trusted vlan 1-4094
        no poe
        switchport mode trunk
        no spanning-tree
    interface vlan 4
        ip address 192.168.1.254 255.255.255.0
    The configuration on ESXi is as follow:
    If I change the vSwitch fixed to VLAN 4 it works.
    Thanks for helping.
  • 2.  RE: ArubaOS 8.x VMC Trunk not working on ESXi
    Posted Oct 17, 2017 10:52 AM
    Try setting the native vlan on the trunk to something you don't use like VLAN 1. The set the trunk allowed vlans to all.
    I add some weird issues with this for a customer as well.
  • 3.  RE: ArubaOS 8.x VMC Trunk not working on ESXi
    Posted Oct 17, 2017 11:10 AM
    Thank you very much. That was the solution. :)
  • 4.  RE: ArubaOS 8.x VMC Trunk not working on ESXi
    Posted Feb 27, 2018 05:20 PM
    This also worked for me on Brocade switches. Thank you!
