Contributor I
ArubaOS 8.x multi Location SSID with different VLANs
Hi all
I setup my frist ArubaOS 8.x MC. Our customer has multiple location which are all connected together (VPN or Layer2 ISP Connections).
Each location has a own Subnetz with own VLAN-ID. There is one Controller on HQ which manage all locations (often is only one 3-4 APs per location).
The employee's need to connect on all locations with the same Wifi credentials.
How can I switch the VLAN based on the location which the user are connecting?
Thanks in advanced.
Re: ArubaOS 8.x multi Location SSID with different VLANs
I assume you will do bridging of client traffic - right?
what do you mean by "The employee's need to connect on all locations with the same Wifi credentials."?
Are they using EAP-PEAP Authentication?
Than you are able to use Radius data to push them into the needed VLAN.
Go to Authentication - Server Group - Server Rules and set a new rule based on Aruba-AP-IP-Address as an example. As Action you will det the VLAN
Contributor I
Thank you very much.
That was the solution. In didn't search in the "Auth Server" Tab. ;)
I have the same scenario with way more than 3-4 APs at each location.  I'm hoping to use your solution, but use some sort of "begins with" as it would be too inneficient to put in every single AP address.  Further thoughts?
