Auba 620 mobility controler with OS 6.1.3.4
  • 1.  Auba 620 mobility controler with OS 6.1.3.4
    Posted Jul 10, 2013 02:42 AM
    I have Aruba 620 mobility controller, and i have configured SSID profile and upplied to the AP group.
    I am able to get the ping from public DNS and as well my controller IP.
    But i was un able to access the internet and controller through WebUI . Can you please guide me how to configure.Helpful, If you could share the relevant documents.
    satish.
  • 2.  RE: Auba 620 mobility controler with OS 6.1.3.4
    Posted Jul 10, 2013 03:33 AM
    Hi Sathish,
    May i know the default-gateway for the client ? It would be great if you upload the copy of tech-support config to review it.
    Do we see the arp entry for the default gateway on the client itself (arp -a) ?
    Thank you,
    Sriram S
    Technical Support Engineer
    srirams@arubanetworks.com
  • 3.  RE: Auba 620 mobility controler with OS 6.1.3.4
    Posted Jul 10, 2013 03:47 AM
    Please find the attached configuration.
    Attachment(s)
    TXT
    Nipun_Aruba_Config.TXT   19 KB 1 version
  • 4.  RE: Auba 620 mobility controler with OS 6.1.3.4
    Posted Jul 10, 2013 03:52 AM
    Can you share me the basic configuration document of aruba 620 mobility controller.
  • 5.  RE: Auba 620 mobility controler with OS 6.1.3.4
    Posted Jul 10, 2013 10:53 AM
    Hi Sathish,
    Thanks much for providing config.
    I could there is one vlan on the controller with DHCp configured and again we have the default gateway to the controller itself.
    Could you please confirm the below things:-
    Are we able to ping the client gateway ?
    Is the client able to do nslookup to google or yahoo?
    Are we able to ping controller gateway ?
    Can we do a traceroute to 4.2.2.2 from controller ?
    You can also reach me at 408.585.1928 for any help.
    Are we looking for any specific configuration on the 620 controller that i can help you?
    From running-config, i see we have pretty much the basic config itself.
    Thank you,
    Sriram S
