I'm comparing some of the functionality between Catalyst switches and Mobility switches, and I need to know if it's possible to fail through from 802.1X, to MAB, to Captive Portal, with a Mobility switch? I'm pretty sure failing from 802.1X to MAB is trivial, but I'm not sure about captive portal. The reason I ask is that I'd like to have a single port configuration for all edge ports that can serve every device/user connecting, whether it's a corporate laptop, VoIP phone, printer, BYOD device, guest, etc. I don't want to have to change port profiles on a port if people move around.
