Beacon rate higher than basic rate?
  • 1.  Beacon rate higher than basic rate?
    MVP
    Posted Feb 26, 2018 06:58 AM
    Looking at an old powerpoint (https://www.slideshare.net/ArubaNetworks/roaming-behavior-and-client-troubleshooting-45383614) and one of the recommendations in there is when you trim datarates is to also change the beacon rate.
    That seems logical, but then the recommendation is to set the beacon rate one step higher then your lowest basic rate.
    Anyone that can explain why?
    It would seem to me if I want to support e.g. 12Mbps, that beacons should also be sent at that rate?
  • 2.  RE: Beacon rate higher than basic rate?
    Posted Feb 26, 2018 09:10 AM
    The presentation that you refer to is mine.  The reason to set the beacon rate one rate higher is so that the AP is a good roaming candidate.  In other words, if the beacon rate is the same as the lowest supported data rate then it is feasible that the device could see it as a roaming candidate, connect to it and then have to roam immediately off of it because it was on the edge of coverage from a power standpoint.  This would especially manifest itself where the AP power is slightly too high because the client might put it higher in it's roaming table.  In the real world if someone has taken time to trim their data rates then I would hope the power is tuned appropriately as well so this is really a non issue.  Either way, it's going to work just fine, you'll just have unnessary roaming if the power is slightly too high and the beacon rate is at the lowest supported data rate.  I hope this makes sense.
    BTW, I've attached an updated presentation that includes speaker notes, Airmatch slides and some updates to the client match slides.
    Best,
    Andrew Hejnar
    ajh@hpe.com
    Attachment(s)
  • 3.  RE: Beacon rate higher than basic rate?
    Posted Feb 14, 2020 04:02 PM
    Very good presentation, I made changes to turn it RW (MKS).
