We have a 7210 that is currently using a 1gb fiber uplink on port 0. we are bottlenecking on this point and i have a 10gb DAC cable that i want to use on port 2. Whats the best way to move over to port 2. i dont want to have 2 uplinks, i just want to move everything over to the new port. Is it as easy as setting the port and a trunk and allowing all the vlans on it(and matching the rest of the config of port 0), or is there more to it then that?
