Blocking some traffic to a specific device on IAP
  • 1.  Blocking some traffic to a specific device on IAP
    Posted May 09, 2017 06:08 PM
    Hi guys,
    I am testing some of the features of IAP and I want to block some traffic (for example youtube traffic) to a specific device. I want to block the traffic specifying the IP address of the device. For doing that, on Access Rules > Role-based > New Role Assignment Rule > Attribute I can't find any attribute that references an IP address
    Is there any way of doing that?
    Julián
  • 2.  RE: Blocking some traffic to a specific device on IAP
    Posted May 09, 2017 06:57 PM
    No. You would use user-roles.
  • 3.  RE: Blocking some traffic to a specific device on IAP
    Posted May 10, 2017 05:52 PM
    Hi Tim,
    Then, if I want to block the traffic for a specific user, do I select the attribute User-Name maybe?
    Julián
  • 4.  RE: Blocking some traffic to a specific device on IAP
    Posted May 10, 2017 05:57 PM
    You would return that role name in the RADIUS response based on policy.
  • 5.  RE: Blocking some traffic to a specific device on IAP
    Posted May 10, 2017 06:01 PM
    But isn't there other way? I am using IAPs with WPA PSK authentication, without using RADIUS servers.
    Julián
  • 6.  RE: Blocking some traffic to a specific device on IAP
    Posted May 10, 2017 06:03 PM
    How are you identifying a user then?
  • 7.  RE: Blocking some traffic to a specific device on IAP
    Posted May 10, 2017 06:17 PM
    My test scenario is very simple. I have an IAP broadcasting one SSID and I connect two users/laptops to this SSID using WPA PSK. Now I want to block youtube traffic to only one client. What are the options?
    Julián
