I have a situation were I can see broadcast from my core switch on some AP's and not others. I have broadcast filter ARP and broadcast filter all on so I'm not seeing broadcast from wireless devices. I have four SSID's and I can see broadcast from my core or closet switch on three of the SSID's but the fourth SSID is hit or miss. I can see some broadcast on some AP's when I do a capture while roaming around. I did a capture one day and could broadcast then I did a capture the next day and didn't see any broadcast in the same area where I did the capture the day before.
We are running 5.0.4.0 with AP 70's, 125's, and 105's. I don't not have the stateful firewall broadcast filter ARP enabled. It's not recommended.
Also, on the same SSID that is hit or miss with the broadcast, I can't get connected using HT. I can connect on my three other SSID's. I have HT enabled on the radio's and SSID but only connect at 54mg. That's on both the 5Ghz and 2.4Ghz ranges.
