CLI - how to Pause?
  • 1.  CLI - how to Pause?
    Posted Mar 25, 2017 03:26 PM
    When i run the Show IP command, the output is scrolled so I can see only the end of it (the mgmt interface data but not the mgmt one).
    I cannot use | more (pipe more) or output to a file becasue the CP CLI is not really a Linux shell. Anyway I can pause the output or funnel it into a file?
  • 2.  RE: CLI - how to Pause?
  • 3.  RE: CLI - how to Pause?
    Posted Mar 25, 2017 04:31 PM
    Thank you Joseph. Though I'm not sure it helps. Maybe I am missing something. I am asking about CPPM (Clearpass) CLI. The url's in the reply are about Aruba OS.
  • 4.  RE: CLI - how to Pause?
    Posted Mar 25, 2017 05:49 PM
    How did I not know that this was about ClearPass?
  • 5.  RE: CLI - how to Pause?
    Posted Mar 26, 2017 02:28 AM
    Sorry for the confusion Colin. I mentioned it is about CP CLI in the question and also selected "Clearpass" as the keyword. Apperantly it was not enough. Will do better next time.
    So is there a way to pause the display or use something else to be able to see the full output of the Show IP command in Clearpass CLI?
  • 6.  RE: CLI - how to Pause?
    MVP EXPERT
    Posted Mar 26, 2017 02:49 AM
    Hey, the only method I know is to use Putty or similiar to access the CLI and then record the putty session as such to a text file then view offline.
    https://www.viktorious.nl/2013/01/14/putty-log-all-session-output/
  • 7.  RE: CLI - how to Pause?
    Posted Mar 27, 2017 03:59 AM
    Thanks Craig. Gr8 workaround! :)
  • 8.  RE: CLI - how to Pause?
    MVP EXPERT
    Posted Mar 27, 2017 04:19 AM
    Glad to help! :D
  • 9.  RE: CLI - how to Pause?
    Posted Apr 03, 2024 10:34 AM
    You can also use Shift + PageUp and Shift + PageDown keys to navigate through ClearPass CLI commands output.
