Frequent Contributor I
Can I block an SSID?
Aruba 3200 controllers running 6.4.1.0.  I want to block an SSID that an employee is broadcasting and using while in the office.  All I have is the SSID.  I also have Airwave.
Re: Can I block an SSID?
Do you have the RFP/WIDS licensed on your controller?
Jerrod Howard
Do you have RFProtect licenses?
Tim Cappalli | Aruba Security
Yes
So I will configure an ids general-profile default
what command to block just SSID "test"
wireless-containment tarpit-non-valid-sta ?
There may be other SSID's that I want to allow that are not configured on the controller.
You use the WIP wizard
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Confidence?
From guide:
Suspected Rogue Confidence Level
A suspected rogue AP is an AP that is potentially a threat to the WLAN infrastructure. A suspected rogue AP has a confidence level associated with it. An AP can be marked as a suspected rogue if it is determined to be a potentially threat on the wired network, or if it matches a user defined classification rule.
The suspected-rogue classification mechanism are:
  • Each mechanism that causes a suspected-rogue classification is assigned a confidence level increment of 20%.
  • AP classification rules have a configured confidence level.
  • When a mechanism matches a previously unmatched mechanism, the confidence level increment associated with that mechanism is added to the current confidence level (the confident level starts at zero).
  • The confidence level is capped at 100%.
  • If your controller reboots, your suspected-rogue APs are not checked against any new rules that were configured after the reboot. Without this restriction, all the mechanisms that classified your APs as suspected-rogue may trigger again causing the confidence level to surpass their cap of 100%. You can explicitly mark an AP as “interfering” to trigger all new rules to match against it.
Thank you
Victor Fabian
I set to 100
now will this actually disable the SSID from broadcasting or just disable anyone to connect to it?
