last person joined: 5 hours ago
Can IAP 325 auto detect controller
  • 1.  Can IAP 325 auto detect controller
    Posted Jul 21, 2017 11:21 AM
    Dear all friend and expert,
    I have 100 IAP 325
    Is there any way for my AP will automatically detect ip of controller. Because if i setting per ap, i will spend alot of time for that as bellow step:
    - set static ip, mask, gw
    - convert iap to campust ap
    - move ap to group ap
    Now, i want to automatically detect controller as below
    - ap will get ip from dhcp
    - after reboot it will connect to controller, and then, i move it to ap group only ?
    Please help me and give some advices
    Thank you so much,
    Lee nguyen
  • 2.  RE: Can IAP 325 auto detect controller
    Posted Jul 21, 2017 11:44 AM
    If you bring all of your IAPs up in a cluster, a single convert will convert them all.
    No need to set static IPs, DHCP will more than suffice.
  • 3.  RE: Can IAP 325 auto detect controller
    Posted Jul 21, 2017 12:11 PM
    Dear jrwhitehead,
    As my understand your ideas is:
    Firstly i will boot one iap and it's master (virtual controller)
    And then i will bring up all ap and it will use auto join mode protoco to join my virtual controller
    After that i will click convert iap to ap campus is that right, please correct me if I'm wrong
    Thank you so much
    Lee nguyen
  • 4.  RE: Can IAP 325 auto detect controller
    Posted Jul 21, 2017 01:59 PM
    Yes, that would work.
