I built a fancy new AP group using my new single band SSIDs... I provision my AP to use the new group, the AP reboots and goes right back in to the default group. Tips?
I went under campus APs, selected the AP changed the group and left the IP the same.
Looks like I can make changes under whitelist as well.
Looks like I had to change it in the whitelist and then provision it for the new group
@WiFivomFranManwrote:I built a fancy new AP group using my new single band SSIDs... I provision my AP to use the new group, the AP reboots and goes right back in to the default group. Tips?
I've this problem before, you can check regulation domain and make sure that your RD has support your ap type.
