Captive Portal/Guest Users without PEF
  • 1.  Captive Portal/Guest Users without PEF
    Posted Mar 30, 2017 09:34 PM
    Is it possible to keep guest users from accessing the LAN without PEF? I have captive portal in effect utilizing it's own VLAN, DHCP and outside DNS and that all works perfectly. However, I am still able to ping internally and connect internally by IP address. Without PEF I am unable to create rules so I'm wondering if there is any other way of securing the LAN from guest users?
    We are using a 650 with ap-105's.
  • 2.  RE: Captive Portal/Guest Users without PEF
    Posted Mar 30, 2017 09:56 PM
    Unfortunately, you cannot without the PEF license..
  • 3.  RE: Captive Portal/Guest Users without PEF
    Posted Mar 30, 2017 10:09 PM
    Thanks Colin for the quick response.
