Captive portal configuration not working!!!!
  • 1.  Captive portal configuration not working!!!!
    Posted Jul 18, 2013 03:09 AM
    I have a internanal network 192.168.5.0 and DNS using 203.82.48.3  203.82.48.4.
    I have made a vlan (192.168.3.0) for guests. done all the captive portal configuration. L3 profile, AAA profile, SSID etc.
    But i dont know how to setup the internet on controller , so that the guest users can  be authenticated on captive portal then to have an access on the internet.
    Kindly Help me.
    Skype ID          ruhail_maqsood
  • 2.  RE: Captive portal configuration not working!!!!
    Posted Jul 18, 2013 03:56 AM
    Is the controller acting as a client gateway for guest ?  And the switch ip on Internet VLAN ?
  • 3.  RE: Captive portal configuration not working!!!!
    Posted Jul 18, 2013 04:01 AM
    Till yet there is no internet on the controller.... Dear i am  a new user on aurba...
    Yes i want to be the controller act as a gateway for the guest users.  In the internal network we diddnt define any VLAN...
    can you add me on skype so that i wil share you my screen through TV session
  • 4.  RE: Captive portal configuration not working!!!!
    Posted Jul 18, 2013 04:05 AM
    kindly help me as soon as posible... i am stucked on this point from last 2 days....
  • 5.  RE: Captive portal configuration not working!!!!
    Posted Jul 18, 2013 05:54 AM
    Thanks for your time here. Once we map the internet vlan port to the controller vlan and configured the ip nat inside; internet and guest-traffc with captiveportal is working fine now.  Kindly keep in touch with us in case of any help you need.
  • 6.  RE: Captive portal configuration not working!!!!
    Posted Jul 19, 2013 01:23 AM
    Hi Sriram,
    I am unable to access the controller to GUI through 192.168.2.1. Through CLI mode and by command" Show controller-ip "
    it is showing controller ip 192.168.2.1 of VLAN 2 but not able to access it...
  • 7.  RE: Captive portal configuration not working!!!!
    Posted Jul 19, 2013 03:00 AM
    Dear Sriram,
    Mac authentication is working fine.
    But captive portal is also not working ... although the valn 3 is in operational mode...
    kindly help me in this regared
  • 8.  RE: Captive portal configuration not working!!!!
    Thanks sriram for your great support.. I get the solution from your support.
    It was pleasure day with you...
