Choosing right power
Let's say Supported Country Maximum Power is 20 dBm ,
In Adaptive radio Management profile
Max Tx Power 17 dBm
and Channel 36 Max is 23 dBm
So at the end what will be the power value
MVP
Re: Choosing right power
[ Edited ]
The controller will limit ERIP to 20 (radio conducted power + ant gain = 20dB). Even if you configure it for 36 and disable ARM, the controller will set the max EIRP for the AP to 20 (the regulatory max).
If you set the max ARM power to 17dB, the controller will set the EIRP of the AP to 17 (radio conducted power + ant gain = 17dB).
Jerrod Howard
Sr. Techical Marketing Engineer
How did you get the value 27 dB,
Thanks a lot
MVP
That was a typo, should have said 17...it's now corrected.
Jerrod Howard
ARM power to 17dB + ant gain ( 4 dBi) =21 dB?
MVP
If you set the ARM power max to 17, or the static power (no ARM) to 17, since the controller knows the AP's antenna gain, it will be
13dB conducted Tx power + 4dBi antenna gain = 17dB EIRP.
Jerrod Howard
