Occasional Contributor I
Cients couldn't get IP address for wireless Guest net.
Hi all,
Cients couldn't get IP address for wireless Guest net.after rebooting the controller .Clients started getting the IP address and working fine.we got the same issue on multiple times.we did not found any  logs for the same
Kindly let me know if any body have some solution.
Regards
ANU
Re: Cients couldn't get IP address for wireless Guest net.
What is providing DHCP.  Are you sure the leases are not used up?
Colllin is right
Please when it happens agains go to the cli and run
show ip dhcp statistics
You will see the free leases... if you see it on 0 thats your issue...
If that the issue you will want to distribute more IPs and also maybe putting a lower lease time on those...  maybe 4 hours if they are just visitors?
Cheers
Carlos
Alternetworks Corp
we alredy checked the same and there is no issue with DHCP and after rebooting the guest master controller everythink works fine .
all the local controller whisch is connected to the master guest got affected due to this issue.
We do not have enough information to solve your problem.  We do not have a diagram to determine what is going on, or what is providing  dhcp and how.
Hi all,
We have Guest controller and local controler.We are connecting local controler to guest controller via Tunnel.
we have seperate DHCP pool for guest access and separte DHCP server configerade for the guest Ip pool and It is connected to Guest controller.
when clints requesting for the IP, it will get from DHCP server
Now Our issue is various local Clints which connected to differnt Local controller and not got IP address.We checked the DHCP server and other thinks realted to dhcp evrythinks works fine and rebotted the server also.It did not works well.
After rebooting the controller ,every clints got the Ip address and works fine
Regards
ANU M
Which controller do you have to reboot to get this working?  Do you already have a TAC case open?
Guest  controller rebooted.we did not raised tac with aruba.'
Please controller information
ontroller ModelAruba650
ArubaOS Version5.0.3.2
Compiled2011-04-05 at 13:45:44 PDT (build 27734) by p4build
ROMSystem Bootstrap, Version CPBoot 1.0.0.0 (build 23274) 2010-01-19 11:11:4
How many DHCP guest clients is that 650 serving? The internal DHCP server on the Aruba controller is only rated for 400 leases.
It is near to 200+ clients...
