Hi AirHeads,
Crazy idea, but I'm hoping it's something viable...
We have a remote site that has a Cisco WLC with a Guest network. We have a remote site that has an Aruba Controller with the same Guest Network. The Aruba site has a GRE tunnel back to the Data Center's Aruba Controller, which acts as the anchor for captive portal and guest authentication to ClearPass. Theoretically, GRE is an open standard, so nothing proprietary happening between the Aruba Controllers. Could I also setup a GRE tunnel from the Cisco WLC to the Aruba Controller and have it do the same.
Client would be untrusted wired client, forced to captive portal for registration and MAC authentication, placed into guest role after authentication on the Data Center controller and forced through the GRE tunnel for all traffic.
The reason we want to do this is we have a content filter at DC that does not exist at remote site with Cisco WLC and instead of installing a new device, we want to try and use existing equipment to accomplish the goal of content filtering.
Thanks.
