Clickshare in ArubaOS 8 controlled WLAN
  • 1.  Clickshare in ArubaOS 8 controlled WLAN
    Posted Feb 21, 2018 04:37 AM
    Dear community
    We have an Clickshare in our Wifi. In general it works but one issue still occurs. If you search the Basis Unit in the mobile App you don't get the Base Unit in the search list. But when you enter the IP address from the Base Unit by hand you can connect.
    From my point of view it is an issue with multicast. Can some help how to check this or do the correct setting?
    Maybe it's important, we did an upgrade from 8.1.0 to 8.2.0.1 yesterday.
    Thanks for helping.
  • 2.  RE: Clickshare in ArubaOS 8 controlled WLAN
    Posted Aug 31, 2018 06:00 AM
    I could help my self with great support from Aruba Switzerland. :)
    First you need to activate "Mobile devices" over LAN:
     Afterwards you can check the AirGroup Server Table for the entry with the CLI-command (of corse you need enable airgroup service first):
    show airgroup server
    That's all. Enjoy.
