Client keeps changing APs
Hello Airheads,
  I have an issue with one OSX client. The user reported slow to intermittent internet. I found that this client constantly (every 5 minutes or so) associates with a different AP. The client is in close proximity to the AP for that section of the building. The laptop will then associate with AP's up to 3 floors above. The AP that is in close proximity has an average of 20 clients connected.
I am at a loss here as my aruba-fu is weak.
Thanks in advance for any advice,
JW
Re: Client keeps changing APs
Do you only see this behavior with Mac OS X ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I see with only this one client computer (which is an OSX machine)
What code are you running ?
Thank you
Victor Fabian
my 3600 controller is running 6.1.3.6
Please open a TAC case in parallel, if you have not already.
I have TAC open now
