Hello guys,I have a MSR2000 with two radios. The data link is via its Ethernet port. I wonder if I can configure both radios to work as to spread coverage
Luiz
If you mean can you run both links at the same time to 'add throughput and load balance' across the wireless links between the same two points, then the answer is that is not supported. The MSRs don't have LACP/etherchannel-esque functionality that way.
Hello Jerrod, this is a simple configuration I need... if possible configure radio to works it?
Attachment(s)
In that case, yes, so long as the 2.4Ghz radio and 5GHz radio are doing client access, not a problem. You can also have one radio doing mesh while the other does client access, or both doing mesh to two different radios.
Hello Jerrod,thank you for your clarification on this question that was.
