last person joined: 11 hours ago
Configure trunk and LAN on 103H
  • 1.  Configure trunk and LAN on 103H
    Posted Dec 03, 2014 11:36 AM
    We have just purchased AP-103H and is working on the configurations. How can we configure the following scenario? Please advise.
    1. Configure Eth0 as a trunk and uplink.
    2. The 103H will get DHCP IP address via VLAN 62 and the controller is on VLAN 62 as well.
    3. The wireless traffic will be tunneled to the controller.
    4. The PC that connects to Eth1 will be placed on VLAN21.
    sohpiechan
  • 2.  RE: Configure trunk and LAN on 103H
    Posted Dec 03, 2014 12:10 PM
    Create / assign ethernet profiles for each port in the AP group settings.
  • 3.  RE: Configure trunk and LAN on 103H
    Posted Dec 03, 2014 01:09 PM
    Do you mean the wired AP profile in the ap-group?
    sophiechan
  • 4.  RE: Configure trunk and LAN on 103H
    Posted Dec 03, 2014 01:19 PM
    Is this setting correct? Which vlan does the AP request for DHCP IP when the uplink is a trunk?
  • 5.  RE: Configure trunk and LAN on 103H
    Posted Dec 03, 2014 01:23 PM
    Yes, that looks correct. The AP will use the native VLAN.
  • 6.  RE: Configure trunk and LAN on 103H
    Posted Dec 03, 2014 01:41 PM
    Is this setting correct for eth1? We want to connect a PC to it and put it in vlan 21.
    Many thanks.
  • 7.  RE: Configure trunk and LAN on 103H
    Posted Dec 03, 2014 02:22 PM
    Looks correct. Are you looking to do authentication on that port or just allow them on.
  • 8.  RE: Configure trunk and LAN on 103H
    Posted Dec 03, 2014 02:29 PM
    We do not want authentication on eth1, just want to switch all the traffic to vlan21.
  • 9.  RE: Configure trunk and LAN on 103H
    Posted Dec 03, 2014 04:45 PM
    Then you should be all set!
  • 10.  RE: Configure trunk and LAN on 103H
    Posted Dec 04, 2014 08:09 AM
    Thanks a lot. We tested the setup today.
  • 11.  RE: Configure trunk and LAN on 103H
    Posted Jun 24, 2015 03:20 AM
    Dear,
    Could you please tell me how can I disable the lower 2 ports on the 103H, which they are E1 and E2 because we will not use them, so I need them to be shutdowned.
    Note that I need to keep the E0 working.
  • 12.  RE: Configure trunk and LAN on 103H
    Posted Jun 24, 2015 05:52 AM
    In the AP group settings, assign them the shutdown profile.
    Tim
