Hi Community:
Is it possible to force that an endpoint is connected to an specific SSID automaticly for the first time without user intervension?
Regards
Karlink
Without user intervention? The user would have to attempt to connect first, unless, their mobile device has a rule to associate to an open network...
What are you trying to do?
Hi Colin:
It is a requirement from a customer, He has a deployment using APs and Mobility Controller with an integration with a third party captive portal provider. He want that all the users that enter to an specific zone will connect automacally to the SSID the first time without any configuration of the user.
