Frequent Contributor I
Controller 7010 LED Status blinking
Hi all.
I have a small problem with controller 7010.
One of local controller's status led are blinking with orange color. the other (3 local) are working fine.
Is there any guide available, or command like in MAS (show alarms) about this?
I have tried rebooting the controller but the led kept blinking.
Also check "show error log" and check the machine status/summary on AMP and found nothing.
Thank you.
Yopianus Linga
Re: Controller 7010 LED Status blinking
Try running the "show log system all" and see if you find anything related to it.
If you don't find anything in the logs , I suggest you open a TAC case .
Thank you
Victor Fabian
Lead Mobility Architect @WEI
