Frequent Contributor I
Controller Downgrade Firmware
After upgrade the firmware to version 8.1, can i still downgrade to 6.5 or 6.4?
Re: Controller Downgrade Firmware
i have done it, because of stability problems with version8. You should do a flash backup of your 6.x installation. than you can just install version 6 and restore the backup. There is no downgrade option in version 8
In version 8, does it still have 2 partition to keep different version of the OS?
Yes, AOS 8 does have 2 partitions..
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
