Controller MSM760
I have an issue with my wifi connection bandwith and i need to make a rule on my controller to indicate the user has the right just to just one connection .
I use authentication by AD.
Cordially,
Best regards.
Re: Controller MSM760
Do you want to limit a user to be able to use a single device on the network? What is being used for your Wifi access?
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
Exactly, I want to limit an user for just using a single device on the network.
I use AD authentication for connecting user is that answering ur answer ?
Up! a little help would be very appreciated !
From a colleague:
"There is a “maximum concurrent session” parameter for local accounts (when the controller is used as a RADIUS server, but with external authentication like AD, I don’t believe it is possible to enforce this."
If you have a Policy Engine like ClearPass, it would be possible to do it with radius accounting.  Microsoft Radius servers do not have this capability.
Thanks for ur answer i already check for clearpass, it's a good choice i think.
i really appreciated this help :)
