Controller Mesh Point errot asap_vap_gone:got vap gone notification on unknown VAP0:1
I configure Wireless Mesh on the controller with basic settings
the mesh portal works well
the mesh point show the following error
then it cannot be shown on the controller
Valued Contributor II
Re: Controller Mesh Point errot asap_vap_gone:got vap gone notification on unknown VAP0:1
Couple of things here,
1. Which AP model you are using for Portal and point ?
2. Do you have any other Mesh deployment nearby ?
Please clarify the above, we can fix the issue.
Cheers,
Venu Puduchery,
I use AP-175 For both
There is no Mesh arround
i ask if the mesh point cannot find the portal
but it is direct connected to the controller
then it cannot see the controller or what is the right boot process
is there any debug commands to see why this Mesh cannot see the controller or cannot see the MESH Portal
I am having the same exact issue as the original message in this thread.  I cannot get the mesh point to join the controller no matter what I do.
I am trying to setup a point to point configuration.
Please let me know if anyone has any sugestions.  These are the error messages on the mesh point.
~ # [ 37.520896] wl0: set MESH_ID(Lamson Mesh, 11)
[ 37.952715] asap_vap_gone: Got vap gone notification on unknown vap:0:1
[ 39.105110] asap_vap_gone: Got vap gone notification on unknown vap:0:0
[ 39.196348] anul_get_max_amsdu_size(1631): WARN: AMSDU size is not explicitly configured
[ 40.174577] anul_get_max_amsdu_size(1631): WARN: AMSDU size is not explicitly configured
[ 40.271704] anul_get_max_amsdu_size(1631): WARN: AMSDU size is not explicitly configured
[ 40.371866] anul_get_max_amsdu_size(1631): WARN: AMSDU size is not explicitly configured
[ 40.468992] anul_get_max_amsdu_size(1631): WARN: AMSDU size is not explicitly configured
[ 364.601423] wl0: set MESH_ID(RecoveryH34dVd4AK+lLFSZW, 24)
[ 364.669977] anul_get_max_amsdu_size(1631): WARN: AMSDU size is not explicitly configured
[ 364.766895] anul_get_max_amsdu_size(1631): WARN: AMSDU size is not explicitly configured
Also I am using AP277s to create point to point wireless bridges.  There is no other Mesh configured APs in the area.
Couple of questions:
* You are at at least AOS 6.4.3 or later?
* These were purged or new and when plugged in to the LAN, controller, came up and you provisioned them as mesh portal and point, and you provisioned these as 'outdoor' or 'auto'
* You haven't modified the AP groups allowed channels
You can ignore the AMSDU messages, until the mesh point is up
Jerrod Howard
We are running 6.4.3.2
These are brand new AP277s that came up on the controller and I was trying to provision them as a mesh portal and point.  I have since factory reset them several times in attempts to get the setup working.
No, I have not modified the AP group allowed channels.
It seems overnight that the mesh point did finally find the controller though.  I now see that the mesh point ap is showing down on the controller.  Before it seemed as if the controller didn't know it was configured as a mesh point.  It only showed it being down in the default AP group.  I have not got the bridge connection working as of yet though.
I am currently seeing the same error messages:
[ 96.765896] asap_vap_gone: Got vap gone notification on unknown vap:0:1
[ 97.857370] asap_vap_gone: Got vap gone notification on unknown vap:0:0
You might open a TAC case and they could help, the console logs can likely be ignored as they are common to see as a mesh point is coming up or down.
If you can, send me a show-tech at 'jhoward -at- arubanetworks -dot- com' and I can look at it. Common issues would be if the portal is on a channel the point can't run, but since they are both 277s, that seems unlikely.
Jerrod Howard
Thank you Jerrod.
I got on the phone with TAC today and we were able to get the point connected to the portal AP.  We had tried various things to try and bring the bridge connection up but there were 2 things that I made note of that seemed to make a diiference.  Im not sure if these confiurations/steps should be nesccessary but at least the point seems to be working now.
In the Mesh Radio profile he changed the Reselction mode from startup-subthreshold to reselect-never.  He mentioned that you would only do this in a point to point setup.
We had to reboot the AP using the command "apboot ap-name <ap-name>" from the contrller and the point AP would seem to start working after we would reboot this way.  In the past I was rebooting the AP by basically removing the power/POE from the AP.
Contributor I
BUMP!
Sorry to step in your post, can I know did support told you the root cause of this?
I'm in the same situation with you as well now.
