Controller RF Locate scalability limits
The controllers RF Locate functionality scalability limits have been tested and are being posted in the next version of the user guide.
RF Locate is part of the controller functionality and should not be confused with VisualRF in AirWave or VisualRF Plan.
Scalability limits:
Under 150 APs in a single master/local domain
AP counts up to 50% of controller limit or 150 APs on a single controller
RF Locate is designed to do basic location tracking and planning for small sites. It is not recommended for large deployments. Large deployments should use VisualRF.
