Frequent Contributor II
Controller base and controller less setup client roaming impact
Will it be any wireless client connectivity impact while he roam from controller base setup to controlless IAP setup for the same SSID, authentication method and VLAN.
Thank you...
Re: Controller base and controller less setup client roaming impact
For stateful applications, yes.
The user will miss a few pings as it performs a full reauth / re-dhcp because the information is not shared between the two environments
Sent from Mail for Windows 10
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thank you for quick reply...
how much time client will take to reconnect the SSID
