Controllers behind load balancer
  • 1.  Controllers behind load balancer
    Posted Jun 22, 2015 03:37 PM
    We have two data centers with Aruba 7220 installed in each DC in Master/Local setup. Plan is to use this set up for our telecommuters with RAP3s. Can I use load balancer (F5 GTM) to load balance RAPs traffic to these controllers?
  • 2.  RE: Controllers behind load balancer
    Posted Jun 23, 2015 02:37 AM
    So you have 1x 7220 as MASTER in DC1 and 1x 7220 as LOCAL in DC2?
    OR do you have 2x 7220 as MASTER/LOCAL in DC1 and DC2 (SUM: 4x7220)?
    Normally you won't terminate a RAP on a MASTER, but you can do that if you want.
    I would recommend the loadbalancing on this way:
    Reserve two public IPs for the Controllers.
    Create two AP-Groups.
    AP-Group-1, LMS-IP: DC1, Backup-LMS-IP: DC2
    AP-Group-2. LMS-IP: DC2, Backup-LMS-IP: DC1
    Now you have to provision the RAPs in the different groups and you load balance them "manual".
    But you can do that with the F5, too.
    Thomas
  • 3.  RE: Controllers behind load balancer
    Posted Jun 23, 2015 08:14 AM
    - Setup your controllers with two public ip addresses.
    - Setup a-record on your public DNS server that has those two public ip addresses (e.g. rap.domain.com)
    - Setup your DNS server to round-robin (https://en.wikipedia.org/wiki/Round-robin_DNS) so that it delivers alternating ip addresses when a device requests that a-record.
    - Provision your RAPs to point to that public dns record (rap.domain.com).
    - Your RAPs will obtain alternating ip addresses for the controller and load-balance
  • 4.  RE: Controllers behind load balancer
    Posted Jun 23, 2015 10:28 AM
    Thank you!!
    Is there a way to overwrite VLAN IDs that are being replicated from Master to Local for AP group?
  • 5.  RE: Controllers behind load balancer
  • 6.  RE: Controllers behind load balancer
    Posted Jun 23, 2015 11:22 AM
    Thank you!
