mom
Contributor II
Custom Captive Portal - no login possible
Hello!
I've uploaded a custom Captive Portal Page to a aruba 7030 controller as described in this appendix:
Reason - the built in CP Page dont scale (mobile devices)....
Now i stuck on an login issue.
If i enter the username and password, nothing happens, the CP loads again.
No error messages in the box above the user box, the user dont get authenticated.
The built in pages are working properly.
The issue exists even if i copy the whole code of an built in CP page into a custom page.
All links and sources of the page are available.
Does anybody knows this issue?
Regards!
Best regards
Matthias
Re: Custom Captive Portal - no login possible
There are quite a few ways that you could have broken it, from controller configuration to HTML.  Where do you want to start?
Colin Joseph
Aruba Customer Engineering
mom
Contributor II
Because of the fact that the html code from the built in site is not working as custom upload, i would say at the controller configuration.
I loadet up the Captive Portal page (top level) and the content (background).
Then i changed the path to the custom page in the L3 authentication captive portal profile.
Im at work on tuesday again, than i can post more details from the configuration if needet.
Thank you!
Regards
Best regards
Matthias
mom
Contributor II
Hello!
This topic solved my issue:
http://community.arubanetworks.com/t5/Security/Stuck-at-Captive-Portal-Login/m-p/251846
My problem was that i copied the default html code.
If the default code is used in a custom Captive Portal, the form has to be changed:
Default:
<form action="login" id="regform" method="post" autocomplete="off" title="Form used by registered users to login">
Custom:
<FORM method="post" autocomplete="off" ACTION="/auth/index.html/u">
 After updating this line, it worked perfectly.
Best regards
Matthias
You can leave everything as it is, you just need to change action="login" to
for it to work. This is where login data will be sent to.
mom
Contributor II
Thank you!
Yea, i was able to resolve it with this line...
Best regards
Matthias
You also need to have a valid public CA-signed captive portal certificate.
Tim Cappalli | Aruba Security
mom
Contributor II
Hi Tim!
I set the Captive Portal to use HTTP.
Apple CNA and other browsers pops up without a certificate warning.
Could there be a problem to use CP with HTTP without an public certificate?
At the moment i see no reason to use CP with HTTPS.
Best regards
Matthias
CNA will not pop via HTTPS without a valid certificate. The only time HTTP should be used is with click-to-accept workflows or informational redirects.
mom
Contributor II
Hi!
OK, thats right.
We just need get an certificate, than we can use HTTPS.
Thank you!
Best regards
Matthias
