Dell W-AP225 Virtual Controller with Aruba IAP220
Hello all,
I am new to Aruba please be kind :). I have an existing Dell W-AP225 (Dell PowerConnect W-ArubaOS Controller Software) as a Virtual controller for 2 existing Dell AP with Aruba OS. The firmware is
And I have an Aruba IAP 220 with firmware to join the mesh.
My questions are;
1. Is Dell W-AP series compatible with Aruba IAP?
2. I understand that in order for Aruba IAP to join a mesh, the firmware needs to match. Should I downgrade the Aruba IAP or upgrade the Dell?
3. Where do one go to download these firmwares?
Thank you very much in advance.
Re: Dell W-AP225 Virtual Controller with Aruba IAP220
1.  It is not.
2.  You should not run those two devices together.
3.  Please read#2
Colin Joseph
Aruba Customer Engineering
Thanks Colin.
I am guessing from your reply, Aruba IAP 225 will not join the mesh with Dell W-AP225 Virtual Controller?
If this is the case then there will be 2 mesh (1 with Dell Virtual controller and 1 with the new Aruba IAP) on the same wireless LAN, and the same broadcast domain for management IP.
Is this OK?
