Contributor II
Difference between route src-nat and src-nat?
Hi Guys, Could someone give me the actual difference between "any any any route src-nat" and "any any any src-nat" with a usecase as to how it works in Aruba?
Regular Contributor II
Re: Difference between route src-nat and src-nat?
Hi Joe_Lee,
Its mainly required when you are working with RAP.
Below is the screenshot from AOS UG.
Contributor II
Hi SumaN, Thanks for your posting, but I think what you have posted only tells me what is src-nat and dst-nat is. However, I am keen to know more about the functionality of "any any any route src-nat" and "any any any src-nat" with a usecase along with the difference between them.
Route src-nat is specifically used in an ACL when split tunneling client traffic on a Remote AP http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/Remote_AP/Split_Tunneling.htm  You would use split tunneling on an access point configured at a remote AP at a branch office so that corporate traffic gets sent back to the corporate headend and internet traffic gets sent locally to the ISP.
Soure-NAT is configured as an ACL for a Campus AP to do NAT translation for a user's traffic on a campus:  http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/ip_access_list_session.htm?Highlight=src-nat
Contributor II
Hi Colin,
Thank you for the post.
Say for example, My split-tunnel ACL's are like this
any any svc-dhcp permit
any any svc-dns permit
user controller any permit
any any any route src-nat <<<<<<<< instead of this if I specify as "any any any src-nat", then what is going to happen to the user traffic?
Could you please explain in detail
I never tried src-nat with a split tunnel rap, but from experience, the results could be unpredictable, or just not work, at all.
Super Contributor II
I think it´ll be forwarded throught he tunnel and NATed to the RAPs inner IP (taken from the central VPN pool on the controller). But I´m not sure.
Cheers,
Christoffer Jacobsson | Aranya AB
Aruba Partner Ambassador
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
Frequent Contributor I
Could there be an error in this RAP split-tunnel document?
In the document 'src-nat' is stated for the splitting policy in stead of 'route src-nat'.
Rgds
Peter
That is incorrect.  It should be route src-nat.
