We are running ArubaOS 5.0.4.1 currently with all M3 controllers.
We are running the wireless for a multiple campus university. The master and two of our locals are at our main campus and we just brought a second campus online with it's own local pointed at our master. Both the guest and enterprise wireless clients are on the same vlan on our main campus. However, the second campus would like to keep the guest traffic on a different IP subnet. That campus has a content filter in place and they do not want to filter the guest traffic.
Our SE recommended we reference the VLAN by name instead of ID that way the name could reference a different ID at each location. However, both campuses use the same name and ID. So, even if I switch over to the name, it is still going to reference the same VLAN ID.
So, we have VLAN 14 "Users" setup on the master and local and all users are currently in VLAN 14. We setup VLAN 666 for the guest users at the second campus. I called it "Public". Is there anyway to have the guest SSID reference VLAN 666 and the enterprise reference VLAN 14 at the second campus and then both reference VLAN 14 at the main campus?
I thought about creating a second guest SSID for the second campus but we are trying to homogenize the campus wireless setups as they were both being done separately and differently before.
Thanks!
