Disable 2.4GHz for a single SSID?
  • 1.  Disable 2.4GHz for a single SSID?
    MVP
    Posted Jan 21, 2015 08:19 AM
    Is there a correct way to disable the 2.4GHz band for a single SSID?
    Removing all the basic and transmit rates isn't allowed apparently.
  • 2.  RE: Disable 2.4GHz for a single SSID?
    Posted Jan 21, 2015 08:22 AM
    Have you tried to set the RF band in the Virtual AP from all to a or g?
  • 3.  RE: Disable 2.4GHz for a single SSID?
    MVP
    Posted Jan 21, 2015 08:23 AM
    See, sometimes the simplest solutions are the hardest to find.
    Thanks!
