Occasional Contributor I
Does APs termination or registration depend upon master controller's total APs support?
Dear Community,
Let suppose I have a 7210 mobility controller, having supported APs capacity = 512, and 3 x 7205 mobilty controllers, having total supported APs capacity = 3 x 256 = 768, as local controllers. I have to install 768 APs in my wlan infrastructure. In that case does master controller limit the total number of APs termination process or not i.e. 512 APs?
Thanks in advace..
Best Regards,
Re: Does APs termination or registration depend upon master controller's total APs support?
Capacity is based on termination. Each controller can only have X primary APs terminated on it.
Tim
Tim Cappalli | Aruba Security
Thanks for your reply Tim.
So in that case I can terminate 256 APs on each local controllers 7205 regardless the limitation of master controller supported APs 512. right?
Moreover, I am talking about centralized licensing feature enable on master controller.
 please suggest.
thanks.
That is correct. The only thing you need to keep in mind is master scaling
but you should be OK in this case.
Thanks Tim, so nice of you.
