Does VLAN mobility work or it is useless?
  • 1.  Does VLAN mobility work or it is useless?
    Posted Jul 01, 2015 10:51 PM
    Hi guys,
    I did some lab work for VLAN mobility, and found VLAN mobility was totally useless.
    I set up 2 scenarios,
    1,single Controller ,single Vlan,two APs,one AP-group,one SSID profile
    I connected to AP1 first, then shuted down AP1's interface, then the laptop automaticly connected to AP2, also the laptop was able to ping to the Controller.Even I turned off the vlan mobility, the result was the same.
    2,single Controller, two Vlans, two APs, two AP-groups, one SSID profile
    I connected to AP1 first, then shuted down AP1's interface, then the laptap also was able to connect to AP2 automaticly, but this time laptop wasn't able to ping to the Controller.
    Also even I turned off the vlan mobility, the laptop still wasn't able to ping to the Controller.
    Is that just me or the vlan mobility is useless?
  • 2.  RE: Does VLAN mobility work or it is useless?
    Posted Jul 01, 2015 10:54 PM
    When you look at the client in the controller, is it changing VLANs or keeping the same one after a roam?
  • 3.  RE: Does VLAN mobility work or it is useless?
    Posted Jul 01, 2015 10:59 PM
    1. You were not testing the vlan mobility feature.
    2. The scenario you are testing should work with no modifications.
    3. Try pinging the default gateway instead.
  • 4.  RE: Does VLAN mobility work or it is useless?
    Posted Jul 04, 2015 11:33 AM
    Thanks, I found why my vlan mobility didn't work.
    I shouldn't shutdown the interface, because for vlan mobility the AP have to send the deauth packet first.
    When I shutdown the interface,the AP will not send the deauth packet.
