Dynamic VLAN for mobile devices
I am trying to set up an SSID on an IAP Controller that will use Dynamic VLAN to put laptops in VLAN 1 and mobile devices (iphones, android phones and tablets) in VLAN 100.  The problem i'm running into is that I'm not sure what Attribute I need and the String to set for it.
I've tried Attribute=Class, String=iphone but that isn't working.  Any thoughts?
Re: Dynamic VLAN for mobile devices
The problem is that a client needs to get an ip address from a VLAN before the type of client is identified.  If the VLAN of a client is changed after that, the client would not know and will not re-dhcp to get a new ip address.  Maybe others have ideas on how to deal with your challenge.
Colin Joseph
Aruba Customer Engineering
Contributor I
I totally agree with cjosep. The VLAN assignment need to be bevor the client get the IP Address. Otherwise the client have a IP address from the wrong VLAN. And it isn't possible to force an ip renew from the Wifi AP or controller. I use this feature ofen based to change the VLAN different APs.
My only idea I have is to solve this with Clearpass. From my point of view there you have the availability to check client details bevor your authenticate and write back the controller role.
