Dynamic or static IP for APs in controller
Hi guys,
Just a quick question. I have a customer with a controller and many APs, each one with its corresponding IP. How can I know from the controller if these AP IPs were obtain by DHCP or if they were statically configured?
Julián
Re: Dynamic or static IP for APs in controller
You would have to type "
show ap provisioning ap-name <name of ap>
Hi Colin,
I have tried this command, the difference I see is
  • When the AP IP is static the items Netmask and IP Addr show the values
  • When the AP IP is dynamic the items Netmask and IP Addr show N/A
Is this correct?
Julián
Yes.
Ok, many thanks!
Julián
